glTF export - OCCT7.5 require RapidJSON
gvb
Post by gvb »
Hello
I am succeeded to export glTF files from FreeCAD using OCC 7.5 features. Current FreeCAD code is ready for glTF export, but OCC7.5 has to be compiled with RapidJSON library and packed into Libpack. Is there the description of build process of Libpack? I am not able to find the rigth repo where I should direct my PR. Or may be Libpack builded manualy?
Also I am not sure that Linux OCCT has compiled with RapidJSON. It is header-only library, so it is not obviouse from package dependancy.
apeltauer
Re: glTF export - OCCT7.5 require RapidJSON
Post by apeltauer »
Building from OCC from scratch:
1. get the source code from (https://gitlab.com/blobfish/occt ) --> fillet fix included
2. setup your machine with cmake
3. get freetype2 and tcl/tk
4. setup cmake
5. build occ
gvb
Post by gvb »
Thanks for reply, I have already done that on my local machine. So my question is about what is a best way to share that with community?
Probably glTF is not popular enough for now, but it is strange for me to have option in FreecadCAD GUI "Export as glTF" witch is not working due to incomplete OCCT build options.
gvb wrote: Thu Mar 11, 2021 7:49 am Thanks for reply, I have already done that on my local machine. So my question is about what is a best way to share that with community?
If this is true, it is awkward.
You have to blame OCCT. It provides the class RWGltf_CafWriter to create glTF files but no way to determine if it was built with RapidJSON, i.e. whether it's working or not.
So, when trying to export to that format you always get an error but when you enable log messages you at least get some information about the missing RapidJSON support.
wmayer wrote: Thu Mar 11, 2021 8:44 pm
What would be an ideal way occt would behave here?
gvb
Post by gvb »
My point is the same - we need rebild LibPack with HAVE_RAPIDJSON defined for OCCT code (see [1][2]). With out it the OCCT test case [3] is failed with that error [1]
$ FreeCADLibs/bin/DRAWEXE.exe
Draw[1]> pload ALL
1
Draw[2]> restore C:/occt/install/data/occ/Ball.brep b
b
Draw[3]> incmesh b 0.1
Incremental Mesh, multi-threading OFF
Meshing statuses: NoError
Draw[4]> set aTmpGltf "C:/occt/install/data/occ/Ball_tmp.glb"
Draw[5]> writegltf b "$aTmpGltf"
Error: glTF writer is unavailable - OCCT has been built without RapidJSON support [HAVE_RAPIDJSON undefined]
Draw[6]>
[1] https://gitlab.com/blobfish/occt/-/blob ... r.cxx#L721
[2] https://gitlab.com/blobfish/occt/-/blob ... r.cxx#L556
[3] https://gitlab.com/blobfish/occt/-/blob ... write/ball
gvb wrote: Fri Mar 12, 2021 7:43 am My point is the same - we need rebild LibPack with HAVE_RAPIDJSON defined for OCCT code (see [1][2]). With out it the OCCT test case [3] is failed with that error [1]
Pinging package volunteers. What say you?
sgrogan wrote: pinged by pinger macro
apeltauer wrote: pinged by pinger macro
vejmarie wrote: pinged by pinger macro
Kunda1 wrote: Thu Mar 11, 2021 8:45 pm What would be an ideal way occt would behave here?
That the class RWGltf_CafWriter is not declared.
vejmarie
Post by vejmarie »
Kunda1 wrote: Fri Mar 12, 2021 12:40 pm
Will take care of that for Homebrew and the snap
