glTF export - OCCT7.5 require RapidJSON
gvb
Re: glTF export - OCCT7.5 require RapidJSON
Post by gvb »
apeltauer wrote: Thu Mar 11, 2021 6:39 am Building from OCC from scratch:
here [1] you can find version of @apeltauer's Libpack with glTF support. @apeltauer, could you please review the the OCCT build options in .gitlab-ci.yml [2]? just in case if I missed something.
[1] https://gitlab.com/gbvbg/FreeCADLibpack ... es/1457063
[2] https://gitlab.com/gbvbg/FreeCADLibpack ... i.yml#L102
looo
Post by looo »
Kunda1 wrote: Fri Mar 12, 2021 12:40 pm Pinging package volunteers. What say you?
rapid_json is enabled for conda-forge occt7.5. packages. But we still cannot update the bundles to occt7.5 because of gmsh failing to compile against occt7.5 (windows).
looo wrote: Fri Mar 26, 2021 6:21 pm rapid_json is enabled for conda-forge occt7.5. packages. But we still cannot update the bundles to occt7.5 because of gmsh failing to compile against occt7.5 (windows).
Thanks @looo, can you link to the error ?
edit: nvm found it: https://forum.freecadweb.org/viewtopic.php?f=42&t=56963
@uwestoehr @apeltauer something to take into account for the libpack for the upcoming release, or is this already being done?
@ppd @Kunda1 can it be done for the snap too?
Thanks for the heads up adrian
Opened https://github.com/FreeCAD/FreeCAD-snap/issues/4
uwestoehr
Post by uwestoehr »
But you don't need to compile Gmsh since comes as precompiled .exe:
https://gmsh.info/#Download
In the LibPack we therefore bundle the .exe and this works fine.
looo
Post by looo »
uwestoehr wrote: Wed May 18, 2022 2:28 am
I guess this is quite old. There is no error currently regarding gmsh in conda-forge land.
I like to keep packages from conda-forge because it is more consistent.
uwestoehr
Post by uwestoehr »
looo wrote: Wed May 18, 2022 9:00 pm I guess this is quite old. There is no error currently regarding gmsh in conda-forge land.
What do you mean with old? https://gmsh.info/#Download leads yo to the latest release.
You write there is no error, but in your post from March you wrote there is.
Can you clarify this please?
uwestoehr wrote: Sat May 21, 2022 5:28 pm What do you mean with old? https://gmsh.info/#Download leads yo to the latest release.
his post with the error is from march 2021, either way, gmsh is not the main issue in this thread, did you read the stuff about compiling OCC with rapidjson enabled? Is that done in the current libpack?
uwestoehr
Post by uwestoehr »
adrianinsaval wrote: Sat May 21, 2022 10:20 pm his post with the error is from march 2021,
Oops. :oops: Sorry for the noise then.
But why did you mention me here? What is the problem?
