Progress thread of New Design456 Workbench - FreeCAD's Direct Modeling workbench
mariwan
Re: Progress thread of New Design456 Workbench - FreeCAD's Direct Modeling workbench
Post by mariwan »
After several weeks, and many problems, I have the basic functionality of my new tool. It is yet not perfect and not completed.
But since many of the options are working now, I would like to share it with you and maybe you leave your suggestion, comments here.
Basically it is 4 direction + Rotation of a face - Extrusion. It uses LOFT and the rotation (I am still not finished how to implement).
These might be useful, or useless .. Don't know .. depending on some applications they might be useful. But in general, this tool will get more functionality in the future as I learn and learn more (hopefully :lol: )
It can be also combined with other tools (direct modeling) to achieve other manipulations. It was hard and it wasn't easy.
There are several bugs that needs to be targeted, even in COIN widget. For example I wanted to show the rotation angels in number but the text is misplaced and just not working yet.
Hope you find it useful or at least get you inspired.
Thanks go to Mario for his rotation script which I really needed to make this rotation works better. Depending on that function I will make a better rotation tool soon after this tool.
https://www.youtube.com/watch?v=l4wzVcbrDls
Roy_043
Post by Roy_043 »
Just a small heads up: your WB currently cannot be installed with Std_AddonMgr:
Error: Unable to download https://github.com/MariwanJ/Design456/a ... master.zip
mariwan
Post by mariwan »
Roy_043 wrote: Mon Oct 11, 2021 8:20 pm Just a small heads up: your WB currently cannot be installed with Std_AddonMgr:
I just downloaded the WB using the Addon Manager.
My version is :
Version: 0.20.25645 (Git)
Hash: 37d9757399b4c2ec30318eb88d7cd7c508246345
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
But my git has no "Master" branch .. It is called "Main"
Roy_043
Post by Roy_043 »
Maybe you have git installed? I don't.
mariwan
Post by mariwan »
Roy_043 wrote: Mon Oct 11, 2021 8:39 pm Maybe you have git installed? I don't.
Would you please try to download latest build?
https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
mariwan
Post by mariwan »
marja1 wrote: Tue Oct 12, 2021 5:19 am
And try to look at this video?
https://www.youtube.com/watch?v=RomaDFQ1WoA
Roy_043
Post by Roy_043 »
marja1 wrote: Tue Oct 12, 2021 5:21 am And try to look at this video?
I have worked on the documentation of the Std_AddonMgr command, so I know how it should work. Most (all?) addons can be installed without having git installed. For your addon this is apparently not the case.
OS: Windows 8.1 (6.3)
Version: 0.20.25997 (Git)
Hash: 77b198048a63f1e9ca15eef64c8042d599a14cf3
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.2
mariwan
Post by mariwan »
If you are able to look at the link .. please don't use master --> mine has no master .. It is main branch.
The problem is there.
It works for me so really don't know what to say. Maybe just downloading manually and extracting the zip file at the MOD folder?
wouldn't that then be a bug in the addon manager that asumes the main branch is called master?
chennes wrote:
could you check it out? I think you've been working with the addon manager lately? sorry to bother if that's not the case.
mariwan
Post by mariwan »
I checked the github.
if you write
https://github.com/MariwanJ/Design456/archive/main.zip
it works.. but not the master ..
It is working for me without changing anything. Don't know why it is not working for you. And regarding the git, FreeCAD uses some executable file which comes with the FreeCAD. You shouldn't be needing git to install the WB
