Python subclass of PartDesign::Subtractive?
jrheinlaender
Post by jrheinlaender »
I create a Hole feature (see viewtopic.php?f=9&t=3413) in Python.
In order to make this work with patterns, it needs to be a subclass of PartDesign::Additive. Is this possible? How?
Thanks,
Jan
logari81
Re: Python subclass of PartDesign::Subtractive?
Post by logari81 »
shouldn't it just be SketchBased (: Additive || Subtractive) instead?
Creating such a sub-class is pretty simple. To the header file add such a line after the class definition of Subtractive:
typedef App::FeaturePythonT<Subtractive> SubtractivePython;
At the end of the cpp file add a block like this:
namespace App {
  /// @cond DOXERR
  PROPERTY_SOURCE_TEMPLATE(PartDesign::SubtractivePython, PartDesign::Subtractive)
  template<> const char* PartDesign::SubtractivePython::getViewProviderName(void) const {
    return "PartDesignGui::ViewProviderSubtractivePython";
  /// @endcond
  // explicit template instantiation
  template class PartDesignExport FeaturePythonT<PartDesign::Subtractive>;
Add to file AppPartDesign.cpp this line:
PartDesign::SubtractivePython::init();
Usually you do the same for the view provider class. But at the moment there is no class ViewProviderSubtractive. So, you can make a typedef to the the nearest view provider class in the descent:
typedef Gui::ViewProviderPythonFeatureT<PartGui::ViewProviderPart> ViewProviderSubtractivePython;
namespace Gui {
/// @cond DOXERR
PROPERTY_SOURCE_TEMPLATE(PartDesignGui::ViewProviderSubtractivePython, PartGui::ViewProviderPart)
/// @endcond
template class PartDesignGuiExport ViewProviderPythonFeatureT<PartGui::ViewProviderPart>;
PartDesignGui::ViewProviderSubtractivePython::init();
logari81
Post by logari81 »
I hadn't noticed that none of the PartDesign features are interfaced in python. In this case you need to implement the missing python for SubtractiveFeature.
However, you need this only because your Hole implementation is based on boolean cut instead of the Groove feature. In the future, when the Groove feature supports arbitrary sketch planes it would be nice to rewrite the Hole feature based on the Groove feature.
jriegel
Post by jriegel »
Yes we do the exposure not automatically. You need it only for the key classes. The rest would only pollute the name-space...
But for the PartDesign key features its necessary!
Maybe we should do that even for the 0.13. Its not very invasive....
Stop whining - start coding!
jrheinlaender
I think I will just wait for the future. For the time being, the Hole feature simply won't work with Patterns. Shouldn't be a problem on the development branch, I think.
mk2
Post by mk2 »
I think a Bore-Tool will be really usefull in the Part / PartDesign WB. Is there somebody which want to develope a Bore-Tool, maybe with the code from jrheinlaender? I could make a file with many standard bore-dimensions. In the moment i can't code something, because im too new in Python and FreeCAD, but i will learn :)
Kind Regards
mk2
eivindkvedalen
Post by eivindkvedalen »
mk2 wrote:I think a Bore-Tool will be really usefull in the Part / PartDesign WB. Is there somebody which want to develope a Bore-Tool, maybe with the code from jrheinlaender? I could make a file with many standard bore-dimensions. In the moment i can't code something, because im too new in Python and FreeCAD, but i will learn :)
I've already started on such a feature (viewtopic.php?f=17&t=4423) some time ago, but I won't work more on it until I have the Spreadsheet workbench finished.
Best regards,
Eivind
