FC0.17 recompute strange behaviour (regression)
easyw-fc
Post by easyw-fc »
Hi, I recently just noticed that FC0.17 has a weird behavior when recomputing a document.
Here the result of a
FreeCAD.ActiveDocument.recompute()
command on a semi-complex object in FC0.17
and the same in FC0.16
and the testing file
rotating_slider.fcstd
(99.12 KiB) Downloaded 47 times
The recompute is also much more slower in FC0.17 than in FC0.16
import FreeCAD
App.ActiveDocument.Fillet.touch()
My releases are:
OS: Windows 10
Version: 0.17.13452 (Git)
Hash: 34633c144de9133c1f9aeb7da783f369cae9bfaf
Python version: 2.7.14
Qt version: 4.8.7
OCC version: 7.1.0
OS: Windows 10
Version: 0.16.6712 (Git)
Branch: releases/FreeCAD-0-16
Hash: da2d364457257a7a8c6fb2137cea12c45becd71a
Python version: 2.7.8
Qt version: 4.8.7
OCC version: 6.8.0.oce-0.17
easyw-fc
Re: FC0.17 recompute strange behaviour
Post by easyw-fc »
I'm adding also a simple change in placement screencast...
FreeCAD0.17 shows a regression:
1) the Placement is getting a bit unresponsive (a bigger delay compared to FC0.16, before updating the scene)
2) the colors get lost during any simple changing of Placement
FC017
FC016
the testing file here:
(99.12 KiB) Downloaded 32 times
Re: FC0.17 recompute strange behaviour (regression)
Can you submit a bug report?
easyw-fc
Post by easyw-fc »
wmayer wrote: Thu Mar 29, 2018 7:45 am Can you submit a bug report?
done here
https://www.freecadweb.org/tracker/view.php?id=3410
mario52
Post by mario52 »
hi
very good catch easyw-fc i delete the recompute() in my macro and now work fine also in the 0.17 FC
With Recompute slow and the color change
Without Recompute and work fine
mario
freecad-heini-1
Post by freecad-heini-1 »
Nice, another tool for to rotate objects. Thank you so much and happy easter.
mario52
Post by mario52 »
hi freecad-heini-1
freecad-heini-1 wrote: Thu Mar 29, 2018 12:08 pm another tool for to rotate objects
old ... forgotten ? feature req: placement - rotate part around its midpoint not yet complete I'm sailing from macro to macro
happy easter.
mario
DeepSOIC
Post by DeepSOIC »
Looks like it was caused by new recompute routine.
Commits: git commit 283ab961b5c4087bf131e74f40d87ddd3335a18b and git commit 283ab961b5c4087bf131e74f40d87ddd3335a18b
Used to work like so:
1. Topological sort
2. for each object, as sorted:
recompute the object if mustExecute() or any dependency (linked or expression-ed) is touched.
-> Recomputing the object touches the object
3. Purge all touched.
Now works like this:
1. Topological sort
* recompute if the object is touched or if mustExecute()
* purge touched for the object
* touch all objects that depend on the object
Changing any property always maked any object touched, a recompute of the object after a change in placement is the result.
How to fix? change back to old logic, I suppose...
DeepSOIC
Post by DeepSOIC »
So, the meaning of object.Touched flag has changed.
Old meaning: object.Touched = the object has been changed since last recompute. That does not mean the object itself must be recomputed, but it does mean that any object depending on this object must be recomputed.
New meaning: object.Touched = object must be recomputed.
Since changing any property except Label makes an object touched, it will be recomputed. mustExecute almost lost its meaning.
So an alternative solution may be to not set object.Touched upon every change to any property.
ickby
Post by ickby »
I can't remember all the details, but I think the reason for this change was the Part hirarchy and scoped links. If a document object linked into a part, it had a link out of scoped and was in error. When draged into the part, a recompute should fix this. However, as it was only touched, mustExcecute() did not return true. Hence the error could not be fixed like this, it needed to be manually marked for recompute. Hence I added the mentioned commit. Seems I unterestimated the impact of this
