corrupted models
shoogen
Re: corrupted models
Post by shoogen »
tanderson69 wrote:
shoogen wrote:OK, i reproduced the problem with the check not showing anything.
Check doesn't show anything, because a compsolid isn't necesarily an error. You never posted that the file in the video prior to the model refine. I can't do anything with a file that has already been corrupted.
The problem is that the behavior changes for the original object and the simple copy, after i did the refine. Please compare the results of your tool at 0:30 and at 1:20.
main.fcstd
(396.2 KiB) Downloaded 73 times
tanderson69
Post by tanderson69 »
Now that I have a relevant file, I am with you. Yes, I can repeat what you show in the video. I am pretty sure we are dealing with more than one problem.
I am getting the following output in the terminal, working with your file. Do you get this and what does it mean to you?
<unknown exception traceback><type 'exceptions.AttributeError'>: 'module' object has no attribute 'CGALFeature'
X Error: BadWindow (invalid Window parameter) 3
  Major opcode: 31 (X_GrabKeyboard)
  Resource id:  0x0
<unknown exception traceback><type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'execute'
hull003: 'NoneType' object has no attribute 'execute'
hull: 'NoneType' object has no attribute 'execute'
hull001: 'NoneType' object has no attribute 'execute'
hull002: 'NoneType' object has no attribute 'execute'
hull004: 'NoneType' object has no attribute 'execute'
shoogen
Post by shoogen »
tanderson69 wrote:Now that I have a relevant file, I am with you. Yes, I can repeat what you show in the video. I am pretty sure we are dealing with more than one problem.
The proxy for a FeaturePython Object can't be attached. Does your branch include the commit 0e6b7a629d0790971f69a6b4719380450851839c ?
  Resource id:  0x0
I don't get this message.
Due to the missing Proxy
jmaustpc
Post by jmaustpc »
Hi Tanderson69
IS this one useful? Its a step file in this topic starting here
viewtopic.php?f=22&t=5739
by page 4 here, I have a list of various combinations of FreeCAD and OCC/OCE
viewtopic.php?f=22&t=5739&start=30#p47457
It seems, from my limited testing, that you need the latest OCE and a recent FreeCAD, for Part Check Geometry to find the errors
this is the file
Tank_all-skull.STEP
(5.76 MiB) Downloaded 85 times
while writing this I see icby has replied
Jim is right: this functionality was added recently by tanderson with commit git commit f51ffa and it uses a new feature from occ6.7 (oce0.15).
so this post is now probably a waste of time? I will leave it here just in case it is useful in some way.
Jim
tanderson69
shoogen wrote:The proxy for a FeaturePython Object can't be attached. Does your branch include the commit 0e6b7a629d0790971f69a6b4719380450851839c ?
No I don't have that commit. But I am not worried about it now as I have the condition isolated outside of openscad. Too be continued.
tanderson69
Shoogen:
I traced this into the OCC::BRepLib_FuseEdges. I created a bug report on oce.https://groups.google.com/forum/#!topic ... Mau4GTySlU. Hopefully something will happen.
I think we can work around this problem. I will create a bug report on mantis. issue #1450
shoogen
Post by shoogen »
That good news. But it only explains the broken shape, not the behavior of the check command, or does it?
tanderson69
shoogen wrote:That good news. But it only explains the broken shape, not the behavior of the check command, or does it?
That is good question. IMHO: OCC uses a "copy on write" strategy. So even though you are making copies the corruption carries through. If you are curious to test this:
experiment 1:
load your problem file.
make a simple copy.
make a simple copy of the simple copy.
refine the last copy.
check geometry on each shape and see the corruption cascade all the way to original. (this is just like your video).
experiment 2:
make a simple copy.
save the file.
close the file.
open the file.
check geometry on each shape and see the corruption doesn't make it all the way to the original.
this happens because Freecad serializes each document objects TopoDS_Shape separately. So shape copies at runtime are linked by OCC, but after a save and load the links are gone. This is how I see it this week. Ask me again next week. ;)
shoogen
Post by shoogen »
copy on write is nice. And i think FreeCAD should do some deduplication on shapes as well (to reduce the file size).
But we are not talking about an OCC operation giving one bad result. This means the the copy on write does not protect other shapes from corruption, if the algorithm of a geometric operations goes wrong.
That's surly the worst bug in OCC I've ever heard about.
shoogen
Post by shoogen »
i got a new file.
please refine the top level object.
airtripper-intact.fcstd
(80.63 KiB) Downloaded 77 times
