Improving documentation of python API
crobar
Post by crobar »
I'm interested in improving the documentation of the python API. Sometimes the help provided for functions is very sparse and it is difficult to navigate using the python 'help' command. I'd like to write more detailed help for some functions using something more like the Google style for python help strings: https://google.github.io/styleguide/pyg ... s#Comments
If I do this, are pull requests for this likely to be accepted?
kkremitzki
Re: Improving documentation of python API
Post by kkremitzki »
BTW, the docs at freecadweb.org/api are a "lite" version because of the size of the docs with all dependency graphs, etc..
The "full"/"pretty" docs can be viewed here although they are due for a rebuild: https://docs.freecad.io
Here's an example of the same page you linked:
https://docs.freecad.io/dd/db6/classFem ... Tools.html
yorik
Post by yorik »
In any case, pull requests that better the doxygen docs would be highly welcome!
crobar
Post by crobar »
Well, the way I tend to work is in the interactive shell, maybe type something like Part. then look at what comes up in the tab completion, if I see a function think might do the job, say, makeLine I'll then do help (Part.makeLine) to see what it does and what the expected input/output is. The problem is, often the docstring is not very helpful, which is why I wanted to improve them.
I find it cumbersome to go search google every time I want to know the calling syntax of a function etc.
DeepSOIC
Post by DeepSOIC »
Yes yes, go for it.
There are a few functions that are next to impossible to figure out how to use. For example, App.addDocumentObserver. Some have undocumented arguments.
Maybe it can be integrated in some way with the debugger WB: https://forum.freecadweb.org/viewtopic.php?f=10&t=21898
PrzemoF
Post by PrzemoF »
crobar wrote:Well, the way I tend to work is in the interactive shell, maybe type something like Part. then look at what comes up in the tab completion, if I see a function think might do the job, say, makeLine I'll then do help (Part.makeLine) to see what it does and what the expected input/output is. The problem is, often the docstring is not very helpful, which is why I wanted to improve them.
That would be great! And we can probably extract/convert then into doxygen format if needed anyway.
crobar
Post by crobar »
ok, well I'll probably start doing this, but it will be gradual, as I come up against things I can't understand from the docstring, a first candidate is probably Draft makeBezCurve. The string is
makeBezCurve(pointslist, closed=False, placement=None, face=True, support=None, Degree=None)
    makeBezCurve(pointslist,[closed],[placement]): Creates a Bezier Curve object
    from the given list of vectors.   Instead of a pointslist, you can also pass a Part Wire.
all well and good, but what do the points in the pointslist do? Obvious from other sources online, but not in the docstring.
