Dissallowing cross coordinate-system links
Re: Dissallowing cross coordinate-system links
A new major regression: https://forum.freecadweb.org/viewtopic. ... 28#p192221
I have a look at this tomorrow.
Current list of open issues:
https://forum.freecadweb.org/viewtopic. ... 30#p187270
https://forum.freecadweb.org/viewtopic. ... 30#p187603
https://forum.freecadweb.org/viewtopic. ... 40#p187903
https://forum.freecadweb.org/viewtopic. ... 28#p192221 -- fixed with git commit 04ac31c
https://forum.freecadweb.org/viewtopic.php?f=18&t=24829
issue #3150: See comment in bug tracker
Werner, I thought a bit about the recompute and isTouched() issue https://forum.freecadweb.org/viewtopic. ... 40#p187903
My thought is that I like to revert the change and not check for isTouched, as you pointed out that it breaks the recompute logic. Now I also don't want to make any major changes to the recompute, this was enough trouble already. So my idea is to solve it within the geofeaturegroup itself. When adding somethign to a GeoFeatureGroup it could touch all link properties (deally check if it has a error and only touch those who have one). This should also enable the recompute.
Would that be an acceptible solution?
It should be tested but it sounds good to me.Would that be an acceptible solution?
I found a new issue with the base features:
1. Create Part cylinder
2. Select cylinder and create body
3. Select the also created BaseFeature and delete it
4. Undo # there are two base features now
5. for every Undo/Redo a new base feature is created
This behaviour is caused by the implementation of Body::onChanged. I think here we can check if an Undo/Redo operation is running and just do nothing in this case. git commit 7d4eafb
One minor thing:
Assuming we have imported a STEP model and create a body but have forgotten to select the model. Now we have an empty body but cannot "move" the model into the body. Wouldn't it make sense to implement the drag and drop of the body to create a base feature on the fly that references this model?
One minor thing:
thanks for the fix, never tried undo/redo...
You can set the BaseFeature property of the body, it will create the BaseFeature when set (or update it if already available). But the drag'n'drop is a good idea, it could work the same: create the base feature if not available, or update if it is already set.Assuming we have imported a STEP model and create a body but have forgotten to select the model. Now we have an empty body but cannot "move" the model into the body. Wouldn't it make sense to implement the drag and drop of the body to create a base feature on the fly that references this model?
Another little thing: the body feature must make sure that the linked base feature is a solid because otherwise following operations don't work correctly.Fixed.
