Bug #2591: Wrong view of a compund of cylinders
issue #2591: Wrong view of a compund of cylinders
Example file attached to ticket.
Description
I created a compound of three cylinders perpendicular to each other.
In draft module, view on XY plane is wrong containing lines that shouldn't be visible.
Steps To Reproduce
Create three cylinders with following data:
Cylinder 1 - radius: 10 - height: 100 - axis 0,1,0 - angle 90° - position 0,0,0
Cylinder 2 - radius: 10 - height: 100 - axis 0,1,0 - angle 90° - position 0,50,50
Cylinder 2 - radius: 8 - height: 70 - axis -1,0,0 - angle 45° - position 50,0,0
Fuse the cylinders.
In draft module, create a shape2DView of the fusion object.
View contains segments that shouldn't be visible.
NormandC
Re: Bug #2591: Wrong view of a compund of cylinders
Post by NormandC »
Link to issue #2591
Comment left to bug report and screenshots added.
This needs to be tested with FreeCAD compiled with latest OCC 7.1.0, which AFAIK brings bug fixes to hidden line algorithm.
NormandC wrote:Link to issue #2591
Thx! :D
NormandC wrote:This needs to be tested with FreeCAD compiled with latest OCC 7.1.0, which AFAIK brings bug fixes to hidden line algorithm.
I've added it to https://forum.freecadweb.org/viewtopic.php?f=10&t=20264
NormandC
Post by NormandC »
That OCC bugs topic is a very good idea!
