OCC Bugs in the Bugtracker
Re: OCC Bugs in the Bugtracker
Checked all open upstream tickets.. still no traction or progress. There are still bugs that need to be opened upstream, see Missing Upstream Tickets in the OP (https://forum.freecadweb.org/viewtopic.php?f=10&t=20264)
Added
issue #4129 Crash on setting certain dimensions in a sketch | Upstream ticket: #31585 which is currently unscheduled on the roadmap
Added:
HLRBRep_Algo removes visible edge | Upstream ticket #31610
Added
issue #2535 issue #2325Pad -> Fillet -> Apply Thickness causes crash (upstream OCC bug) | Upstream ticket: #31601
there is a patch submitted by @abdullah for this issue. Perhaps it can be merged?
Reason: wrong ticket number
OCCT 7.5 beta has been released. Need to check all open upstream bugs. Created a 7.6 Roadmap section.
Edit: all bugs in initial post have been updated
I think that ticket link should be issue #2325?Kunda1 wrote: ↑Fri Aug 21, 2020 8:52 pm Added
issue #2535 Pad -> Fillet -> Apply Thickness causes crash (upstream OCC bug) | Upstream ticket: #31601
FWIW, FreeCAD-0.19(git hash commit: a48dd3aa2c41), built with openCASCADE-7.5.0, crashes with the test file from the ticket.
Thanks! I've fixed it in the OP and the recent post
Edit: please notate the ticket that it still crashed with 7.5.0 (please add you About info to the ticket as well
I've added:
issue #2526
issue #3142
issue #3435
issue #3679
issue #4076
issue #4247 (is fixed in OCC 7.5)
issue #4275
issue #4487
issue #4311
issue #4350
Edit: updated
issue #2526
issue #3142
issue #3435
issue #3679
issue #4076
issue #4275
issue #4487
issue #4311
issue #4350
Edit: updated
- HakanSeven12
I don't know why but I can't reply in bug tracker. Yes it's also an OCC bug.
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
While by far the preferable way is to have the issue merged by OCCT, I talked with Kurt and he is aware of these patches (I think I made two of them if I remember correctly), so he can apply them while packaging. It is not ideal, but at least saves us from some crashes...
