Feature #2335: export in .obj file should use the objects labels
issue #2335: export in .obj file should use the objects labels (Related is also issue #2336: importing .obj file should use the object names as labels)
Looks like a user named damian in the bug tracker offered a fix. His repo link is 404 (his github user is @caceres
Maybe someone can ping him on github ?
Re: Feature #2335: export in .obj file should use the objects labels
bump
Should we keep pursuing this ticket or close?
please advise
feedback from the community is welcome...
Would be nice to have. Another good choice is to propose the FreeCAD filename prefix.
cadfunforfweeee
Post by cadfunforfweeee »
On Ubuntu Linux 20.04 (e.g. installed using apt-get install freecad), all you have to do is edit ./src/Mod/Arch/importOBJ.py and change "obj.Name" to "obj.Label" where it gets written to a file (search for outfile.write).
Not sure if it's possible/if issues can arise using non-unique object labels in FreeCAD or what might happen in a Wavefront OBJ file with duplicate object names (or for import?) but this works a charm.
If you know how to use git/diff/patch, git diff fix against master branch commit 0926a4148bcff11249fd4f56bc30256102ffe105 below:
diff --git a/src/Mod/Arch/importOBJ.py b/src/Mod/Arch/importOBJ.py
index 0dd361d186..2cd5a156dd 100644
--- a/src/Mod/Arch/importOBJ.py
+++ b/src/Mod/Arch/importOBJ.py
@@ -208,7 +208,7 @@ def export(exportList,filename,colors=None):
else:
offsetv += len(vlist)
offsetvn += len(vnlist)
- outfile.write("o " + obj.Name + "\n")
+ outfile.write("o " + obj.Label + "\n")
# write material
m = False
Since my last post the naming of export files was improved.
