Bug #2792 Negative distances measured in feet/inch calculated incorrectly
issue #2792
When specifying a negative distance in <ft>'<inch>", such a -7'3", FreeCAD actually calculated the following distance: -7' + 3" = -6'9"
This is obviously wrong...
Steps To Reproduce
- Set units to ft/inch
- Create an object
- select move object
- select relative / copy
- specify second point as -7'3"
In the python console, you'll see the following:
>>> Draft.move([FreeCAD.ActiveDocument.Rectangle001],FreeCAD.Vector(0.0,-2057.4,0.0),copy=True)
-2057.4 = -6'9" instead of -7'3"
Additional Information OS:
Ubuntu 16.04.1 LTS
Version: 0.17.8939 (Git)
Build type: None
Hash: cb16eda2165d1af34ebbd73628f82aa00037f667
Python version: 2.7.12
Qt version: 4.8.7
OCC version: 6.8.0.oce-0.17
Re: Bug #2792 Negative distances measured in feet/inch calculated incorrectly
This is part of a bigger issue I realize. I've attached this bug to a previous thread: Problem with negative values in InputField https://forum.freecadweb.org/viewtopic. ... 13#p157013
bump
