eigen2 support disabled
yorik
Post by yorik »
Apparently EIGEN2_SUPPORT is now completely disabled in Eigen > 3.2 (I have 3.3 now on debian). I guess we have one more porting to do :(
Compiling now stops with this kind of message:
In file included from /home/yorik/Sources/FreeCAD/src/Mod/Mesh/App/Core/Approximation.cpp:59:0:
/usr/include/eigen3/Eigen/Core:275:2: error: #error Eigen2-support is only available up to version 3.2. Please go to "http://eigen.tuxfamily.org/index.php?title=Eigen2" for further information
There are several changes listed there: http://eigen.tuxfamily.org/dox/Eigen2ToEigen3.html
Not sure I understand much of what's written there, but I'll try... Soon I'll become the official porting person... :)
PrzemoF
Re: eigen2 support disabled
Post by PrzemoF »
fedora 22 with eigen-3.2.5, compilation doesn't fail, so it might be distro specific or some version after 3.2.5
looo
Post by looo »
I have found this here:
http://eigen.tuxfamily.org/dox/classEig ... olver.html
replace "# include <Eigen/LeastSquares>" with "#include <Eigen/Eigenvalues>" in Approximation.cpp line 59
sgrogan
Post by sgrogan »
On Windows and Ubuntu PPA 3.2.5 compiles, there is a deprecation message.
From Yorik's link I think deprecated in 3.2.x and totally removed in 3.3
"fight the good fight"
According to http://eigen.tuxfamily.org/dox/classEig ... derQR.html the needed changes are:
1. Remove EIGEN2_SUPPORT
2.
-# include <Eigen/LeastSquares>
+# include <Eigen/QR>
 using namespace MeshCore;
@@ -700,7 +700,9 @@ double SurfaceFit::PolynomFit()
     //std::clog << b << std::endl;
 #else
     // A.llt().solve(b,&x); // not sure if always positive definite
-    A.qr().solve(b,&x);
+    //A.qr().solve(b,&x);
+    Eigen::HouseholderQR< Eigen::Matrix<double,6,6> > qr(A);
+    x = qr.solve(b);
 #endif
     _fCoeff[0] = (float)(-x(5));
However, I have to first write a unit test and check if everything still works the same way.
But EIGEN2_SUPPORT is also used for kdl in the Robot and Path modules and I haven't tested if the work without. If not then we have to update the kdl lib in the hope it uses the Eigen3 API.
yorik
Post by yorik »
The above change seems to work okay. There are apparently other changes in eigen3.3 too, which seem unrelated to the EIGEN2_SUPPORT removal, for ex:
[ 59%] Building CXX object src/Mod/Sketcher/App/CMakeFiles/Sketcher.dir/planegcs/GCS.cpp.o
In file included from /usr/include/eigen3/Eigen/Core:295:0,
                 from /home/yorik/Sources/FreeCAD/src/Mod/Sketcher/App/planegcs/SubSystem.h:29,
                 from /home/yorik/Sources/FreeCAD/src/Mod/Sketcher/App/planegcs/GCS.h:26,
                 from /home/yorik/Sources/FreeCAD/src/Mod/Sketcher/App/planegcs/GCS.cpp:27:
/usr/include/eigen3/Eigen/src/Core/util/Meta.h: In member function ‘Eigen::SparseSolverBase<Eigen::SparseQR<Eigen::SparseMatrix<double>, Eigen::COLAMDOrdering<int> > >& Eigen::SparseSolverBase<Eigen::SparseQR<Eigen::SparseMatrix<double>, Eigen::COLAMDOrdering<int> > >::operator=(const Eigen::SparseSolverBase<Eigen::SparseQR<Eigen::SparseMatrix<double>, Eigen::COLAMDOrdering<int> > >&)’:
/usr/include/eigen3/Eigen/src/Core/util/Meta.h:190:40: error: ‘const Eigen::internal::noncopyable& Eigen::internal::noncopyable::operator=(const Eigen::internal::noncopyable&)’ is private
   EIGEN_DEVICE_FUNC const noncopyable& operator=(const noncopyable&);
I think I'll comment out all the kdl stuff in Path for now, it has never been used so far, it is there mostly because Jürgen was thinking on using it in Robot...
yorik
Post by yorik »
Ok I could pass this point. It was a workaround introduced to solve a big in eigen3.2...
diff --git a/src/Mod/Sketcher/App/planegcs/GCS.cpp b/src/Mod/Sketcher/App/planegcs/GCS.cpp
index 5df8e74..799c1d5 100644
--- a/src/Mod/Sketcher/App/planegcs/GCS.cpp
+++ b/src/Mod/Sketcher/App/planegcs/GCS.cpp
@@ -30,14 +30,17 @@
 // NOTE: In CMakeList.txt -DEIGEN_NO_DEBUG is set (it does not work with a define here), to solve this:
 // this is needed to fix this SparseQR crash http://forum.freecadweb.org/viewtopic.php?f=10&t=11341&p=92146#p92146,
 // until Eigen library fixes its own problem with the assertion (definitely not solved in 3.2.0 branch)
+// NOTE2: solved in eigen3.3
 #define EIGEN_VERSION (EIGEN_WORLD_VERSION * 10000 \
                                + EIGEN_MAJOR_VERSION * 100 \
                                + EIGEN_MINOR_VERSION)
-#if EIGEN_VERSION >= 30202
+#if EIGEN_VERSION >= 30202
+#if EIGEN_VERSION < 30290 // this is eigen3.3 apparently. Bad numbering? This should be safe anyway.
 #define EIGEN_SPARSEQR_COMPATIBLE
 #endif
+#endif
 //#undef EIGEN_SPARSEQR_COMPATIBLE
yorik
Post by yorik »
wmayer wrote:But EIGEN2_SUPPORT is also used for kdl in the Robot and Path modules and I haven't tested if the work without. If not then we have to update the kdl lib in the hope it uses the Eigen3 API.
Ok Kdl is now commented out everywhere in Path, and it compiles OK.
For Robot, apparently KDL+eigen3 works: http://www.orocos.org/forum/orocos/oroc ... roblem-kdl
But indeed the current version we have doesn't work when removing EIGEN2_SUPPORT. I'll update to the latest version (hope it won't break anything...)
Changes so far: https://github.com/yorikvanhavre/FreeCAD/tree/eigen33
yorik
Post by yorik »
KDL is updated, FreeCAD now builds succesfully with eigen3.3
Unfortunately the Robot WB is broken now :(
>>> import Robot
ImportError: /home/yorik/Apps/FreeCAD/lib/Robot.so: undefined symbol: _ZN3KDL19ChainJntToJacSolver8JntToJacERKNS_8JntArrayERNS_8JacobianEi
Sounds like you have to do a full rebuild at least of the Robot module.
